Did some reading on the air induction system with a front mounted Gov. There is some supporting data that shows that the gov may restrict the airflow over the 2-4 cylinders. I wanted to take air from the Right side of the engine so I mounted the cooler on the right side of the Firewall. I used the support behind the wall so it is nice and strong with no other external mounts.
Some have ducted the exaust of the cooler to the lower part of the firewall but time will tell if that will be needed.
