The Pitot heat controller does not come with hardware so I decided to make a mount on the inside of a rib so that it can be easily removed if it were to fail. It slides under the mount on the aft side of the wing and it has 2 screws into 2 nutplates on the fwd side for one handed removal.
The Pitot/AOA Lines were ran. I made a short conduit through the walkway ribs and then through gromets in the rest of the ribs.
