Once the Servo was mounted, I got the Wires and harnesses ran through the wing. Installed the 9 pin D sub on to the servo and installed a 4 pin Seal tights connector in the wing root for the SV net and I will get a 3 pin Seal Tight connector for the power and Disconnect plug also at the wing root.
