Pauls Web Site
Date:  2-21-2016
Number of Hours:  1.30
Manual Reference:  Pges 14-9 and 9-7
Brief Description:  Aileron rigging
First I set the reflexor at neutral stroke to elimnate any chance of control mismatch. I then leveled the aileron bellcrank and used a sprit level to set stick neutral. Following the builders manual I assemble the CS 5 and CS12 pushrods and adjusted the female ends to set the specifed up and down travel (25 degrees max) Figures are for the left wing down position.
Once I had the correct travel I replaced the locknuts and tighten them in accordance with the builders manual and AC 43.13.1B table 7-1.
Aileron Rigging left wing down left aileron
Aileron Rigging left wing down right aileron
Aileron Rigging left wing down bellcrank
