Pauls Web Site
Date:  1-26-2016
Number of Hours:  1.50
Manual Reference:  Pages 9-6, 14-7
Brief Description:  Stripping out original rigging
Inspected and disassembled the original rigging psh rods. All rod end bearings badly worn, CS5 5/8 steel, CS12 bowed. New parts ordered from Aircraft spruce.
Note: Manual calls for the rods to be 1/2 inch OD 2024 T6 Aluminium. Given the loads encountered I will use 1/2 inch OD 4130 T5 Steel with females adjusters on each rod (The original set up had only one for the system on the control column)
Original Aileron push rods close up of rod end damage
