Brief Description: Upper wing prep and micro filling
Indentifed area on top of wing that required dry micro to make flat. Prepared areas for repair using manual pg 3-16 Step 2 instructions, filled in accordfance with Step 3 Feather fill. Made up a mix using west systems 206 resin, 105 hardener (25:5) and 410 (beige) micro fill. Fill low areas and some minor dings on the leading outer egde of the wing.
