Brief Description: Prepared and hi coat primed right side of aircraft
Continued sanded high spots on fuselage in accordance with the building instruction manual and Peters advice. Painted Hi coat primer on right side of aircraft and some areas on the left wing. found sond areas that need more sanding and filling before priming and I will attend to thos soon.
