Almost finished fitting the canopy. I made several more little trim cuts and decided it was time to finish the F-631A's. I riveted them together after making a drilling template so I could do it with the canopy on the frame and it on the fuse. I just crawled inside to do it. I then marked the holes that will get drilled through the canopy and into the roll bar and the F-631 frame. I still have a little work to do around the "joggle" where the canopy starts around the corner to the front.
