The Rose's RV-9A
Date:  10-25-2006
Number of Hours:  2.50
Brief Description:  Continuing Tank work
This evening I fabbed the T-410's for the left tank and fit them. When the fit suited me, I drilled them using the brackets I made last nite as a template. Then I cut the big hole in the inboard rib that serves as the access hole which the fuel sending unit is mounted to. I worked the T408 access plate and the T407 reinforcement ring. I finished the evening by dimpling the rivet holes that I drilled in the T-903 inboard rib. Next is finishing up the reinforcement plate and the inboard rib. I'll try to take some more pictures tomorrow evening.
