The Rose's RV-9A
Date:  9-19-2006
Number of Hours:  1.50
Brief Description:  Check riveting from yesterday
I went through all the rivets I put in yesterday and only found 3 that weren't good. I think they were acceptable but I drilled them out and replaced them anyway. I then riveted on the rear spar. That was pretty time consuming due to all the different rivets but it went really well. I'm now ready to put the left wing in the wing stand. Reva came out and we decided that we were going to build both at once and laid out the wing stands to make sure there was adequate room. The next time I get out there to work, I'll fasten the first set of stands to the floor so I can get the left wing off the bench to make room to do the right one. Then assemble the right one to this stage. It looks like we're making some progress, it's just hard to remember that there are a lot of little projects, that when completed will be a completed airplane.
