The Rose's RV-9A
Date:  5-31-2009
Number of Hours:  20.50
Brief Description:  May Update
I've gotten so far behind on putting what I've done into Kitlog on the computer that I thought I'd just do a month update. I've worked all the time in May on various empannage tips. Fiberglassing, Sanding, adding Micro balloons, more sanding, priming and more sanding. I purchased a gallon of Rage Gold and some Evercoat based on what I read on VAF. I like it alot for small fill ins, but the best tip yet is from Dan Horton who suggested that you put enough microballoons on the first time so you only have one consistency to deal with when sanding. If you don't mix it the same and apply from two or more batches, it's a bitch to sand. Anyway his suggestion works very well.
