Finished sanding the elevators and gave one a coat of flat black paint. I read where it's easier to see if you use black. As luck would have it, it looks really good and what I put on just as well have been primer. I'll sand it off with 320 wet and give it a coat of primer when it warms up again. I sanded on the rudder some more and I think it's ready for the first coat of something. I think I'll shoot it black and see what happens. I removed the bellcrank from the fuselage and drilled the mounting hole for the a/p control and put the bracket for the a/p in place. I'll get Reva to come out and help me shoot the rivets.
