The Rose's RV-9A
Date:  9-6-2008
Number of Hours:  3.00
Brief Description:  Rudder Cable Fairings
Made and drilled both rudder cable fairings to the fuse. Then I taped off a place and primed the fuselage where they will be and the fairings. I installed them and the rudder cables along with them. Worked on the right wing tip. Also started the static lines. You might notice that the dates on the pictures don't match the date of the log. I'm trying to get the log caught up to date and took a bunch of pictures after the fact.
