The Rose's RV-9A
Date:  12-26-2007
Number of Hours:  6.00
Brief Description:  More Fuselage work
Today I backed up and did some work that I had put off before rolling the fuselage over. Namely the rudder bars. After much study and searching on the internet, I finally decided on a hole spacing for the adjustment of the bars and drilled both aux. longerons for them. Then I fabbed up the F-6118 Rudder brace with the lightening holes and drilled it. Then I fitted and drilled the F-695 fwd fuse gusset to the firewall. Then onto the F-728 Bellcrank channel. I had not riveted it to the bottom skin yet so I did that with Reva's help. She's a great bucker!!! She got to be the first one in the fuselage, so I took the picture. I still have to fit the bellcrank, but for the most part, it's done. I also drilled the shoulder harness anchor. I'm off till the 7th, other than a couple of days of paperwork so I should get alot done. I have to put an order into Van's for some things this week.
Rudder bar adjustment holes
Reva Bucking Bell crank rib
Making airplane noises.
