The Rose's RV-9A
Date:  11-17-2007
Number of Hours:  5.00
Brief Description:  Fuse fitting
Today I finished drilling and fitting everything forward of the F-704. I found the F-724's and F-722 baggage parts and fit them into place. That seems like everything I need to do before I dissassemble it and prime it. I spent a couple of hours going over the instructions and drawings trying to make sure I wasn't missing anything. I did find a couple of holes for the static line that I hadn't put in, so I did that. I assembled the brake pedals but I'm not going to install them until I turn the fuselage over. I can't see any reason to crawl underneath and try to drill them accurately when it can be done from above after I roll it over.
