MICHAEL'S WEB SITE
Date:  1-1-2016
Number of Hours:  0.00
Brief Description:  Rudder mods Trim
Decided to add the capability for trim using a hinge attached to the rudder TE and actuated by a Ray Allen servo. To allow for this, I need to route wires to the area where the servo will be located.
Tim Olsen did the following write-up http://www.myrv10.com/N104CD/upgrades/20071104/index.html
Ordered parts from Van's to build an access plate and doubler. Wire will be sheathed in braided nylon sheath. This will be offset from the rudder skin by wire-tie (same as VS parts). This run will terminate in a CPC that will be common with the lighting for the tail. CPC ordered from mouser.
