Since completeing the horizonal stab I've not been happy with the elevator hinge bracket alignment. I mentioned this to the factory & in their typical style, immediately supplied me with a complete set of matched replacement brackets, thank you Kyle. I spent today replacing them, taking great care not to damage the spar, after priming the mating surfaces I then riveted the new brackets in place. The alignment of all the brackets is now as it should be.
Before, the bolt should be parallel to the edge of the skin
