Both sidewall trim panels did not fit at all well around the windscreen bow. I needed to unglue (with a low temp heat gun) the vinyl then trim the fibreglass panel to fit properly. I re-glued the vinyl and the fit is now much better. I drilled the panels in the required positions with a 3mm bit then match drilled the inner skins in preparation for installing the rivnuts.
