PGC & KLH helped me install the engine today, it's only temporary so I can trim the cowl before the fuselage goes to the paint shop. Peter kindly lent me his crane which made the task almost effortless. The cowl is not at all well finished from the factory, disappointingly so in fact & will need a LOT of work prior to painting but at this stage, the task is to trim it to fit complete with cut-outs for the exhaust pipe & heater air inlet then remove the engine back to its crate whilst the fuselage spends a few months in paint.
