This morning I fitted some small lengths of continuous grommet to the ribs where, if a cable tie holding a loom were to fail, the loom would rest, a fiddly job but I think worth the effort. I then assembled a loom for the rudder mounted anti-collision beacon (two lengths of 2 core 18ga. shielded Tefzel) & installed it. Next task was installing the M4 rivnuts to the rudder cable adjuster box & trial fitting the rudder cables. I'll need to double check which is left & right as they are different lengths.
