Des' Web Site
Date:  8-1-2016
Number of Hours:  4.00
Brief Description:  Rear Fuselage
Once again, a long time between building sessions.
Today GAM & I deconstructed the rear fuselage in order to remove rib 6. PGC has been to the factory again & is bringing replacement ribs home for me. In addition to the factory replacing rib 6, I elected to purchase the latest revision upper fuselage ribs as I believe they will result in a better fit of the skins. Rib 6 needed to be replaced eventually anyway as a result of a service bulletin so time spent now will hopefully save many headaches in the future.
A shadow of its former self
Rib 6 removed
Rib 6 removed
Still more de-riveting to do
