Des' Web Site
Date:  4-2-2016
Number of Hours:  3.00
Brief Description:  Rear Fuselage
Today I finished this rear section of fuselage. The build manual has a note that says "ensure that the correct sized rivets & bolts are used" however nowhere are the required sizes mentioned!! For rib 8 I used 15mm x 4.8mm rivets & AN3-5A bolts with a thick (standard) washer under the bolt head & a thin washer under the nut.
More work in this than I first thought
Rib 8 mounting, nuts in safety
Ready for the next rib
