Des' Web Site
Date:  3-29-2016
Number of Hours:  5.00
Brief Description:  Rear Fuselage
I spent quite a few hours today trial fitting the rear fuselage parts and surveying where the required tailwheel version mods will be. I have quite a few holes to open up. The tailwheel tyre is 215mm (8.5 inches) diameter & the bottom of the fuselage sits 400mm (16 inches) above the ground giving plenty of clearance.
Trial fit
Trial fit
The external strap is very tight
Good ground clearance
