Des' Web Site
Date:  2-17-2016
Number of Hours:  8.00
Brief Description:  Right Aileron
Today I disassembled the right aileron, adjusted & reprimed the ribs & then riveted it back together. The lumps & bumps have reduced in magnitude, still not perfect but I'm afraid they will have to do. I installed it on the wing to check the trailing edge alignment & the inboard end was 10-12mm high! I'm not having any good luck with this thing at all. I left all but 2 of the leading edge rivets out so I will be able to adjust the twist out relatively easily but that's now tomorrow's job.
Disassembled
Disassembled
This will have to do
Now to get the twist out of it
