Manufactured a spacer to fit between the spar & lower rib in order to relieve stress in the area. Riveted the ribs, two hinges & corner brackets to the spar. I left the control horn & lower hinge clecoed in case the spacer does not work. Drilled & primed the hole in the top rib for the strobe wiring to pass through.
