Brief Description: Pitot, Static & Angle of Attack sense lines
I'm using "tees" to transition from the stiff, nylon hose to more flexible PVC hose for the instrument sense air. Today I made a bracket to hold 3 tees on the unused main landing gear channel, the nylon hoses will enter one side & PVC hose exit the other. The 3rd port on each tee will be used for system testing and will normally be plugged. If the PVC hose proves to be unreliable, I'll replace it with nylon which would add significantly to the degree of difficulty of the task!
