Today I started making the mock-up of the instrument panel dash & bulkhead (Rib 3). I've used timber from the fuselage kit box so as not to waste new material, the instrument panel mount is pivoted so I can work on both the front & rear of the panel at a comfortable angle. The two pieces will be separate but be able to be easily spaced at the correct distance from each other to produce looms of the correct length.
