The position I had in mind for the fuel hose support did not work out so I installed another rivnut in the support angle closer to the centre console which I think will be better. I'll also be supporting the cables & hoses under the dash on the centre console side skin flanges, prior to installing those rivnuts, I glued the vinyl on the right side skin, the left is already covered.
