I continued working on the brake system today. I relocated the hole position for the tee piece to be more central to the pedals, I'm reasonably confident this will be an improvement on the factory system. I'll delay installing the calliper hose end fittings until I have produced & installed the new axle spacers.
Reservoir & hose to bulkhead fitting
Hoses to bulkhead tee from co-pilot master cylinders
