I've constructed the loom from the "under dash Garmin connector" to the autopilot roll servo then on to the pitch servo. This will continue on to the centre fuselage connector but I'll once again leave that until I can ensure the correct length of that section of loom. I tested this & the joysticks loom on the bench with the servos connected, all functions operate as expected. This loom also carries the fuel tank quantity sensor wires that will find their way to the fuel tanks next to the fuel hoses under the floor.
