Today I cut the right wing fuel tank skin for clearance of the main landing gear leg, providing the cut is correct, it was a fairly straight forward job using the Dremel tool & nibbler with the edges being filed smooth & finished with ScotchBrite. I also started sanding the rivets on the bottom skin.
