This morning I helped Richard the painter clean his spray booth and install new filters in anticipation of commencing applying colour to the fuselage in the very near future. After lunch I was able to retrieve the missing rivet tail with the use of the magnet attachment on my borescope (a very handy tool indeed) & complete installing the rivets per the service bulletin on the lower surface of the right wing. PGC then kindly helped me turn the wing over so I can commence the rivet replacement on the upper surface, thank you again for your time.
Handy retrieval tool
Rivets & holes cleaned prior to applying sealing compound
