Drilled the holes in the side skins for the brake line fittings, I hope to have braided hose from the calliper to the side skin with AN4 fittings. Also drilled out 11 rivets from each side, countersunk the holes & installed flush rivets to allow the wing/fuselage fairings to sit flush against the skins. Have marked potential positions for some of the fairing rivnuts.
