Des' Web Site
Date:  3-9-2020
Number of Hours:  3.00
Brief Description:  Front Luggage Compartment
Spent a couple of hours today preparing the luggage compartment skins, a slot needed to be formed in three of the pieces to allow clearance around existing gussets, with those cut, a trial fit shows quite a good fit but lots of holes to be match drilled. I'll need to plot new positions for throttle/choke cables etc. on the firewall & think of methods for securing components to rib 3 so fastener tails don't cause a hazard by protruding into the luggage compartment.
Gusset protruding through slot
Floor to be cut out for inspection holes
Extends about 100 mm below bottom of rib
