Finished installing the rivets in the fuselage front left side skin, a few little lumps but at this stage OK. PGC, JAC & KLH gave me a hand to move the tables & trial fit the main landing gear leg, thank you all. To our surprise the fit is quite good with 3 of the 4 bolts inserted easily, one will need to be led in with a guide pin. The bottom skin will be a little bit of a challenge to fit with the side skins not aligning forward of about half way.
