Des' Web Site
Date:  11-5-2019
Number of Hours:  5.00
Brief Description:  Forward Fuselage
This morning I polished the paint on the inner skins, it's not a perfect finish but will suffice given its position, then clecoed the skins in position, I'll probably rivet them in after the outer side skins are installed. I then moved on to riveting the top steel brackets to the firewall mounting channel, some fettling was required but got there in the end. I'm now preparing to install the firewall starting at the cowling fastener strips. Next, I think I'll install the brake lines from the master cylinders to the parking brake valve whilst I still have good access.
Today marks the 2,000 hours point in the build.
Inside skin paint polished
Firewall mounting channel riveted
Cowl strips test fit
