Deburred, dimpled the holes that require countersunk rivets, turned the rear edge & primed the front top skin. Primed the spacers for the left side skins (will do the right side tomorrow) & the front edge of the centre top skin. I primed some other smaller parts that will be hopefully installed over the next couple of days. Rib 001 needs to be removed so I can dimple one hole on each side then rivet the front skin to those holes prior to reinstalling as it is impossible to rivet them when in position. That will require a bit of juggling to reassemble, we'll see how it goes.
