Des' Web Site
Date:  4-8-2018
Number of Hours:  5.00
Brief Description:  Centre Fuselage
I've discovered yet another issue with my kit. The stringers that support the fuselage side skin splice are holding the skin 3mm from the vertical frame. If I were to rivet there would be VERY unsightly wrinkles in the skins. Another email is on its way to the factory.
Right side
Right side
Left side is worse
Left side is worse
3mm gap between skin & vertical flange
