Spent a few hours in the workshop today on the throttle assembly. I drilled the bolts for the cables & cut some brass tube to use as spacers for the stops, drilled another position for the forward stop to maximise travel & reassembled the lot. I'll leave the parking brake valve alone till I'm ready to install the assembly.
