Des' Web Site
Date:  8-2-2017
Number of Hours:  6.00
Brief Description:  Forward Fuselage
I've been really busy with work over the last week & I'm off on another 6 day trip tomorrow.
Today I disassembled a lot of forward fuselage structure so I could drill holes in two of the fuselage side doublers & also drill holes for the brake hose that goes from the calipers to the parking brake valve. The holes were deburred then coated with primer prior to installing the grommets.
Holes drilled in doubler
Holes drilled in floor ribs
Grommets in with test fit of hose
