Des' Web Site
Date:  7-25-2017
Number of Hours:  8.00
Brief Description:  Forward Fuselage
Over the last 2 days I've installed the rudder/brake pedals along with the brake master cylinders. The master cylinder shafts were all adjusted to be the same length which should provide the same resting angle for all pedals, I want the pedals to lean forward at the top as far as possible to avoid riding the brakes. By adjusting the tension of the mount bolts/nuts, all pedals now move freely. Castle nuts with split (cotter) pins were used in lieu of self locking nuts.
Torque tube bearing
Torque tube bearing
Stainless steel rivets for grip
Castle nuts with split pins
