Today I manufactured the remaining 2 spacers for the modification to the main gear vertical angles then deburred & alodined them all. I'm going to attempt completing that modification tomorrow after painting the required areas. PGC kindly transported the remaining parts for the canopy mounting structure from the factory, thank you and today I clecoed them together for a quick check of their fit. Whilst they are a large improvement on my originals, quite a bit of work will be required to improve them, I found lots of holes drilled to the wrong size or not drilled at all and some misaligned holes also. I'll spend a lot of time on these parts over the next few weeks between work commitments.
