I spent a lot of time surveying the forward fuselage for parts fit, etc. Some parts need holes drilled to match mating parts, some parts have been poorly formed & some parts are missing. These issues will be relatively straight forward to remedy however the main landing gear vertical angles require quite a lot of force to be applied for the jigs to fit when the landing gear bolts are installed, I shall be seeking factory advice as to a fix for that.
