Finally able to get back to the project after being away with work for almost 2 weeks & a full day's mowing. Today I sanded then primed the filled rivet heads in the luggage compartment. I gave the area a fine sand then sprayed several coats of the finish paint on the golf club extension floor & box parts as well as 2 inspection hole covers. I hope the paint will be set enough so that GAM & I can rivet those parts tomorrow. The remainder of the luggage compartment will be painted after that step is completed & the final rivets are filled.
Rivets sanded & primed
Golf compartment box
Golf compartment end wall & inspection hole covers
