Quite a bit achieved today, I was able to mark & drill holes for mounting the luggage compartment cross-members & floor supports, deburr & prime the luggage compartment skins & drill holes in fuselage stringers for the static pressure port tubing supports. I'm toying with the idea of installing a FLARM antenna at the forward base of the vertical stabiliser, under the fibreglass fairing, so I will install an RG400 cable along the lower right hand stringer for that, I drilled holes for its supports today.
