Des' Web Site
Date:  9-3-2016
Number of Hours:  6.00
Brief Description:  Rear Fuselage
This morning I was able to de-rivet then alodine the adjustment plates for the rudder cables and re-assemble them with 4mm c/s rivets kindly donated by PGC, thank you. Using some continuous grommet, I lined the holes in ribs 6 & 7 in order to protect the rudder cables in the unlikely event they rub, another idea stolen from PGC, the rudder cables are now installed. PGC paid a visit this afternoon so we took some time & did a trial fit of the luggage compartment, all the pieces seem to fit just fine despite not being properly prepared. Still quite a few hours of work to perform on the rear fuselage but finally, some real progress is being made.
Rudder cable adjuster plates alodined
Protection for the cables
Fairleads fitted
Fairleads fitted
