Des' Web Site
Date:  11-15-2014
Number of Hours:  3.00
Brief Description:  Left Wing
Marked out the position of the pitot/AOA hose grommet holes in ribs 1 & 12 then drilled them & the holes in ribs 2- 6 to 14mm dia. I have made a very slight deviation from the plans in that I have riveted the aileron pushrod guide from the guide side of the rib. This is so that in the future, if replacement of the nylon guide is required, I can access the rivet heads from the inspection panel in the lower skin adjacent to that rib. P.S. DON'T DO THIS, the plans are correct!!!
Marking out for grommet holes
Holes drilled
Holes drilled
Aileron pushrod guide
