Des' Web Site
Date:  8-16-2014
Number of Hours:  1.00
Brief Description:  Rudder
Not much time available today. Clecoed the rudder frame together, will need to produce a doubler (from some 0.032" stock) to fill the gap between the bottom rib front flange & the spar in order not to stress the area. Otherwise, it looks O.K. I'll need to check that the addition of the spacer does not throw the skin alignment out, before riveting.
Rudder control horn
Rudder control horn
Spacer required
Spacer required
