Clecoed and riveted HS reinforcement bars to rear spar halves. Positioned and riveted elevator hinge brackets to rear spar. Bolted elevator center bearing to rear spar assembly. Torqued and sealed bolts. Clecoed and riveted reinforcement angles to HS front spar.
