Marked the bend lines inside the trim tab. Taped the wedge in place inside the outboard end of the trim tab and clamped it to the bench. Used the rivet gun to bend the tabs. Repeat for the inboard tabs. Clecoed and reamed the control horn to the trim tab. Trimmed and de-burred the horn pieces. Measured, positioned and drilled the aft hinge half to the trim tab. Disassembled and dimpled as directed.
